autopilot
- janesville, WI Rock County
Had a call to a CNC shop with a oil filter pump that had the heater elements fail at about 10 mouths old (this is the second set in 2 years). The elements look like waterheater units but were supplyed by the manufacture of the filtration system. Connected in series at 480 volt but rated at 230 volt, I know ohms law says this will work but can you use a 230 volt device like this? The elements faild in a rupture type manor (split down the length) Said unit is built with this from the factory but seems a little odd to me. Trying to find the manufacture of the elements for there view but have had no luck, anyone ever run into this before?
