ElectricianJeff
- Southern Illinois
I have run into another that I could use some help on.
I am rewiring a rehab for a customer. They wanted the receps. in the living room all split. Hot on the bottom and 3-way switched on top. I have done this several times but never with a three-way involved but didn't see it as a problem. I roughed with line on one 3-way and the recep. load on the other 3-way switch. When I roughed the receps. in I used 12/2/2 wire since I had some on the truck and having not done this before thought the extra neutral might come in handy. When I went to finish today I elected to just pig-tail the 4 neutrals in each recep. since I didn't think it really would matter as to the operation of the 3-way. I broke the brass clip on the line side, black on bottom, red on top.
The result was I had 120 V on the bottom nada on the top. All my connections appear solid and I have 120 V at the line side of the 3-way. It was getting late but I did take some meter readings at the load side that would make me think I have an open neutral.
What gives? Do I need to separate and break the neutral clip at the recepts? I thought this would be easy but its got me scratching my bald head. Any help, as always, is greatly appreciated.
Jeff
p.s. I hope my explanation makes sense.
Jeff
