767 Greenlee
physis
I'm interested whether anybody's used one of these before and what they think of it.
iwire
Massachusetts
Of course, hundreds of times, used to own one till it got stolen.
e57
For anything but busting slugs it would be a waste of time and therefore money. Even for busting slugs there is money better spent these days. If you have say a crimp die.... Sure.
IMO if you have a lot of pipe to bend - get an electric pump &/or bender. If you have more that say 6-90's in 2" RMC - money is better spent sending a lacky to a rental joint if you have one.
nakulak
its the only way. the small ram is better than the one piece pump/ram cause it fits in tight locations. hole saws may be cheaper but I never use em to punch holes.
al hildenbrand
Minnesota
Electrical Contractor, Electrical Consultant, Electrical Engineer
Physis,
I picked up a used 767, the pump, hose & piston, 25 years ago. I'm still using it. I've replaced only the 3/4 die, in that time.
If I had relied on hole cutters, I shudder to think how much I would have spent replacing them.
I love the fact that I don't have to lean in and shove, which the hole cutter requires. Box physical confines can make the lean-and-shove awkward, at best.
The 767 will do up to a 4" trade size hole, as I recall. Using a 4" hole cutter is a potential wrist wracker.
dcspector
Burke, Virginia
I still have mine to 4" will never part with it. I paid $1300.00 for it. Al agreed on the wrist breaker hole saws. I prefer to simply pump it till it pops.....OOPS! that did not sound right.......
gndrod
Ca and Wa
I had the same thing happen also. Many tools were stolen but were recovered when some guy called me one night from 'The Dew Drop Inn' lounge. Evidently there was a bet between the locals as to what the tool did and I had engraved my name and phone number on the casing. After going down to the bar I found out where the tool came from and locked in on the guy that had my other tools. I was lucky to get most of the tools back other than a Sawzall. rbj
physis
Soooo.....what's it do RBJ? :grin:
Just kidding. :smile:
cadpoint
Durham, NC
Yeah, I happen to lookup some toys and the prices the other day before
this thread, I've never given this tool any thought. 1731,1732...
A pump is on most jobs, or brought in just in time when required.
physis
The one I've been using does 4" and it's a way more respectable operation and end result than any drilling method.
