Really? What is totally different about them? I admit I have never taken both apart and inspected them side by side by I imagine the principle is very similar. I was just informed that there is a type that have some sort of lever which tightens the connection. I have never seem that type, maybe that is what you were referring to?
Sorry to those of you I offend. I do have a very pessimistic view of most tradespeople i come across. I hope my experiences are just much worse than average.
Someone dissected a wago and backstab receptacle and posted a picture. I can't seem to find it and it might have been on another forum. Anyway it clearly showed the difference between the two.
The backstab just had a spring that put pressure on the wire. The Wago or Ideal Push-in also has a spring but it actually digs into the wire, making a better connection.
If you pull a wire out of a Wago you can look at the copper and see where the spring dug into it.
Someone mentioned not being able to reuse them if you have to pull out a wire. You can reuse them and it says so on the package. Well most of them anyway.
I have some 6-port Ideals that say on the package not to reuse those.
I haven't had any trouble out of them except once I failed to get the wire all the way in. I have since learned better ways of inserting the wires.
I've been using them for 2 years in the field and longer than that in an industrial setting.
They are also a lifesaver when you find a box with only a couple on inches of wire in it and you need to make a splice!:thumbsup:
