goldstar
- New Jersey
- Electrical Contractor
The strap is designed to be removed if necessary. I had one installation where there was a service 150 amp rated disconnect ahead of the ATS and I had to float the neutral. And yes, the white wire was a # 6 and is folded over. The generator is a 10K unit (45 amp output) serving a 150 amp panel. I folded the wire so it would fit more securely in the lug.So it's not a screw bonding jumper but a small piece of bus.
The white conductor at the left looks like the strands are folded over.
