Now I see the "Class T" label just to the right. They are fast acting fuses. From Coopers Site:
I'm thinking if the breaker tripped, and the fuse didn't, then the fault must have been prior to the fuses.
Unless someone just turned off the breaker, or someone has replaced the fuses.
The space-savers. Counterpart of the KTN-R/KTS-R LIMITRON fuses, but only one-third the size; thus, particularly suited for critically restricted space. A single-element fuse; extremely fast-acting. Provides a high degree of current limitation on shortcircuits for excellent component protection. Must be oversized in circuits with inrush currents common to motors, transformers, and other inductive components (will give only short-circuit protection). Commonly applied in electric heat circuits, load centers, disconnect switches, meters, stacks, etc.
