:huh::?:blink:
I know... right,
dude ...... DEcafe:lol:
got a lot going through that brain of yours it can be overwhelming, take a breath, go to the movies, take a date to dinner!
:huh::?:blink:
A MLO, lighting and appliance panelboard, rated 100 amperes, is permitted by the NEC to be installed
on, and protected by a 200 ampere feeder. Key Answ. False, Ref.408.36
Thank's guy's for the help! I just get so caught up in trying to understand this.
I have had no Exp. on a MLO. I confess I don't know what it stand's for?
I have read 408.30 through 408.37. I understand the 408.34 (A) and (B).
Went to index and that bring's me to 408.35,408.36. Went enternet and typed in MLO
Panelboard's and Mike's page came up on one site. I see I am not alone on this.
It would have to be a single phase 480 to 120/240 transformer to match the question and the answers.What is the primary current and the secondary neutral current on the trransformer shown below when the secondary currents on phase A and phase B are 22 and 38 Amp's. respectively? Answ. Key Ip-15A,
In-16A.
It is a 480 to 120 Trans. I don't know how to draw on site. Do I have to draw for you?
I must confess that my family has a medical thing happining now and I am feeling the stress of
that. It hard to think, when stress is on your mind. Thank's
I don't need you to draw it. It is a simple math thing. Tell us how you think it should be solved. You do have to think a bit about the the primary current. The secondary neutral current just like the neutral current on any 120/240 volt multiwire circuit.Yes, You are correct. Sorry that I didn't say that. Do you need me to try and draw it?
I think it is a simple math thing, that I am not seeing. I did so well on Mike's work
book on Trans..
In-16A.
What minimum size THW Con. is permitted to be tapped from a 400 Amp. feeder when the lenght of the tap conductor does not exceed ten feet? Key Answ. #8.
Did I do this right? 240.21(B)(1)(4) Ref. Is my math right? 400/10=40 Amp.. Table 310.16,
75c, # 10 =35Amp's, # 8=50 Amp's. So a #8 is the one.
I came up with #10=35 Amp's. Would 240.4 (D) apply, say it was a 10 foot tap or less and it was a
300 Amp. feeder. 300/10=30 Amp's. Not sure how 240.4(D) applies on this one?
Did I do the Cal. right on that Tran.. I can see Second. side , but on the Pri. side if we take
7200kva/(480x1.732=831.36) or 7200kva/831.36=8.66Amp's. Did I do the Kva right?
Can't see the thread now, but it was 22 and 38, so I added them and x 120 volt's (per winding,
120/240 Second. I know on Mikes any three uses 1.732. Thank's for respond.
Have new thread up on 10' tap rule.
never mindRegarding the answer's For the B to ground Ques. are:
120/240=208
100/200=173
240/480=415
300/600=519
200/400=346
I remember on a DVD that Mike said something about it.
