cloudymacleod
just bend it! and git er done
That's regarding trigonometric functions, and tangent is the ratio of Y to X coordinates of a point on a circle whose center is at 0,0. Though that has it's basis in geometry also, the point of tangency I referred to is where a straight line intersects a circle at one point only. That point of intersection is the point of tangency. A tangent line to a circle is perpendicular to a radial line from the center of the circle to the point of tangency. In trigonometry, the radial line would be the hypotenuse.jwelectric said:A simple saying that I have learned and use in the class is:
Oscar Had A Heap Of Apples
The equates to;
The Sine of the angle is the result of the side Opposite divided by the Hypotenuse (Oscar Had)
The Cosine of the angle is the result of the side Adjacent divided by the Hypotenuse (A Heap)
The Tangent of the angle is the result of the side Opposite divided by the Adjacent (Of Apples)
This is why I asked the question I did after reading this post
I'm content at the moment with just figuring that out.cloudymacleod said:just bend it! and git er done
iwire said:The radius and circumference are always directly related.
A given radius will always result in the same circumference, it has to or the radius must be variable.
tallgirl said:What, mathematically, is the "take-up" in relationship to the radius of the bender?
iwire said:I do not believe there is a direct relationship between the take up and the radius of a hand bender.
The take up of a hand bender has as much to do with the radius as the the place the bender maker places the arrow to start the bend.
tallgirl said:Thanks -- that explains the brain mush.
I'm trying to figure out how to lay out a 2" offset using a pair of 22 1/2 degree angles, then a length of tubing, followed by an 8" offset using a pair of 30 degree angles and my brain won't let me.
1793 said:Check out this link. I'm sure I'll hear about this but, I would start with the 8" and then do the 2".
tallgirl said:I've been staring at that website for days now and don't know how to translate any of that into how I stick the piece of conduit into the bender to get the bends in the correct location. I'd like to figure this bending stuff out before I return to New Orleans with the brilliant idea that sticking EMT in walls first is a great way to get people into their houses faster
And thanks for the tip -- I was going to start with the 2" offset first, then bend the 8" offset.
iwire said:EMT on the other hand is a breeze.
1793 said:There had been a discussion on this somewhere her before. This level, No-Dog, is kind of nice but I found it did take a few bends to get the hang of its use.
I hope this helps and good luck.
Tallgirl,tallgirl said:I've been staring at that website for days now and don't know how to translate any of that into how I stick the piece of conduit into the bender to get the bends in the correct location.
tallgirl said:The problem I'm trying to solve is getting something into the walls so the sheetrock or plaster can go on (since that doesn't require a license to do), then the wires can go in later. The issue is going to be which steps require a licensed electrician, which require some form of supervision, and which can be done by volunteers trained to do various steps. If anyone knows the answers to all those questions, a PM would be very welcomed.
Rockyd said:Celtic,
That's my bender your using....No AC battery required to run that baby, just Pop-eye arms on 1-1/2" to track the clicks!
Bob NH said:I think that putting EMT in the wall is not going to save you time.
Someone could be nailing boxes to studs and drilling holes through the 2x4s. The licensed electrician can come along with a helper and string NM about as fast as they can pull wire through EMT.
If someone wants to get picky about it, I suspect that running EMT probably requires a license as well.
