Cutting cover plates
mdshunk
Right here.
peter d said:
Gee I don't know Bob, that doesn't seem accurate enough. ;) :D
All joking aside, I have had plates made by a woodworking buddy on his CNC router. I needed two that were two gang plates with a 3 Despard switches in the one gang and a single pole in the other. I could have ordered that plate from P&S or Mulberry, but it would have had to be metal. I supplied my buddy with a several 2-gang nylon blanks to make them out of so that everything matched well in the end.
LarryFine
Henrico County, VA
Electrical Contractor
iwire said:
:grin:
I don't want your to talk I want you to die.
Why do they always shoot at Bond, but once they have him, not only do they rig a slow death, but they then leave him alone?
Why do criminals throw the empty gun at Superman after they shoot him over and over and the bullets had no effect? :-? Why?
iwire
Massachusetts
Dr. Evil: Scott, I want you to meet daddy's nemesis, Austin Powers
Scott Evil: What? Are you feeding him? Why don't you just kill him?
Dr. Evil: I have an even better idea. I'm going to place him in an easily escapable situation involving an overly elaborate and exotic death.
:D
The director said to?
brantmacga
Señor Member
Georgia
Former Child
dremel tool w/ a cut-off wheel works great. somebody mentioned that earlier in this post. you have to go slow w/ the p&s nylon plates because they melt easily. the thermoplastic plates cut the cleanest. to me, its easier to use the dremel by yourself for trimming instead of the belt sander; unless you have a stationary belt sander.
c2500
South Carolina
Belt sander is the first choice. A table saw as a second. One must go very slowly with the table saw though, or the plate may be relocated into a wall. The key to dealing with the hard plastic is to cut very very slowly. And did I mention very slow on the hard plastic?
c2500
480sparky
Iowegia
LarryFine said:
Why do they always shoot at Bond, but once they have him, not only do they rig a slow death, but they then leave him alone? Why?
I was thinking about Batman & Robin, myself.
iwire said:
For cutting $0.30 plates nothing less then a CNC high pressure water jet cutter should be used. I keep this one in a trailer behind my truck. :D
Do you have a generator next to it, or just hope they have three phase and a spare properly sized breaker on your jobs?:roll:
HighWirey
I am fortunate. My brother has a homemade CNC, 24" x 24" bed. Draws the cutoff (or cutout) in Autocad, imports it, wacks it! Flawless.
Priceless, well except for the beer.
Best Wishes Everyone
lat1
i have tried most of the methods mentioned here, besides the cnc laser, and the other day i discovered the BEST method out there. if the tile guy is on the job borrow ,his wet-saw. super straight, clean, and accurate. plus the tile saw blade is a little less intimidating than a chop/table saw.
360Youth
Newport, NC
Hack saw, coping saw, or my prefered method, if you have a good surface to secure the plate and not scratch the surface, screw the plate face down and variable speed sawzall.
