moonshineJ
- USA
Here is scenario (this conversation resulted from the suspected ?dirty? 450 VAC bus voltage, perhaps affecting some electronics):
#2 generator output wave shape is ?fairly dirty with noticeable noise on the peaks?
#1 generator output wave shape is ?extremely dirty with really bad clipping onpeaks?
The most interesting thing: ?When you run them in parallel, a clean signalis provided, but as soon as you single up on one, it becomes dirty.?
If the opposite were true (good outputs from each individual generator, but ?dirtyvoltage? on bus, when they run in parallel) ? I would give a half dozenpossible reasons. But this one?
I recommended to those folks to ensure that the DC outputs of each voltage regulator look good on an O-scope. I rule out the failure of any one of six diodes of the brushless exciter?s rectifiers, as this would cause BIG problems. I also recommended to check if there are any loads on bus having SCRs, or similar devices, e.g., I saw some bad "dirt" coming from operating on-demand (tankless) waterheaters.
What else possibly could cause this problem?
