Note that Vcg must be negated because its arrow is backwards so to speak.
jim dungar said:Rattus,
You call the voltage Vcg but then you say that really needs to be Vgc in order to solve Kirchoff's Law.
I know I am stretching when I say; before we can apply some standard circuit analysis formulas to your method of describing a 120/240V circuit some modifications need to be made, but it certainly sounds like it.
Rick Christopherson said:violates Kirchoff's law regarding summation
Rick Christopherson said:This is just too funny. And I thought it was going to be a boring afternoon. :grin:
I haven't looked through all of the numbers in the table, but the very first thing that jumped out at me was the statement, "Note that Vcg must be negated because its arrow is backwards so to speak."
This is the issue I had the first time around. When you acknowledge that you need to negate this phasor's magnitude, it means that either the phasor is improperly defined, or it violates Kirchoff's law regarding summation. Regardless which of these two alternatives you choose is immaterial, but it should be raising red flags that you have misplaced the minus sign somewhere.
Adding phasors and adding vectors is the same, in the sense that you place them tip-to-tail, yet you have shown two phasors being added that are tail-to-tail, which is by definition, subtractive.
Phasors are not arbitrarily assigned based on a changing point of reference. They are mathematically defined from the voltage function (in this example) for which they represent. I would have to do some reading on this, but it has something to do with Euler's Identity, which frankly, I don't remember a thing about.
LarryFine said:I like the yummy drawing. It makes perfect sense to me.
I also say that the entire discussion is much ado about nothing. :roll:
rattus said:Larry, it is about TRVTH. I am trying to show that, contrary to popular opinion, the voltage on the two single phase legs can be described as 180 degrees out of phase.
I am also trying to demonstrate that Kirchoff's voltage law is satisfied with yumm or yuck.
Either way, the sum around the loop is ZERO.
quogueelectric said:Well everyone knows that the centertap neutral is to reduce the shock hazard to human life right??
Not unless you are in the tubrattus said:I thought it was a way to provide 120V and 240V to the loads. I think also that an isolation transformer reduces the shock hazard. A grounded neutral or grounded conductor increases the shock hazard.
quogueelectric said:Not unless you are in the tub
They must have messed with B+rattus said:How about those dead plumbers in the crawl space before they came out with double-insulated drills, battery powered drills, and GFCIs?
So you think nm cable is dangerous to those not having electrical knowledge?rattus said:How about those dead plumbers in the crawl space before they came out with double-insulated drills, battery powered drills, and GFCIs?
quogueelectric, with all due respect, I would like to try to keep this discussion civil and on topic. Can we address your questions in a separate thread?quogueelectric said:So you think nm cable is dangerous to those not having electrical knowledge?
Mivey -mivey said:...Maybe we should refrain from using the term out of phase. I have come to understand that there are some who take this to mean a time delay (like in the audio sense), which is not even under consideration as far as I understand. ...
I'm lost again. We are engineers, not scientists doing original research. Everything we do is covered by a code, standard, recomended practice. External references are what we live by.mivey said:...I don't think external references are going to help either as we are talking about the terminology WE use.
