peter d
- New England
What else would anyone expect out of them?
To keep water out, which usually means a bit of duct seal or silicone on the top.
Marc
I have noticed the code is good for you when you want it to be and a waste when it is in your way. :wink:
Considering they are a funnel pointed up the last thing I expect of them is to keep water out.
Of course on painted homes after a few paintings they are pretty well sealed.
Which is exactly why you need to silicone the snot out of them for them to be effective. In fact, it was bad duct seal around a sill plate that caused water infiltration into my panel, which I had to replace.
Iwire is on top of that one, always drill the hole in the structure upwards.
Pierre, you want to share the code violation or just talk smack to marc?
LOL @ the last 7 messages! Anyway, If you drill the hole upwards, and use a sillplate, Doesnt that make a very sharp bend in the SE cable?
~Matt
That's the kind of bend I make by over-bending the cable before fixing it in place.Just using a sill plate requires a VERY sharp bend.
~Matt
Yeah, I think drilling down, sealing the heck out of it with some 50 year silicone, then a silplate on that would be the best option.
~Matt
I only use ductseal, never used silicone in my life either.
I have personally never used SE cable outside... Here we use pipe and wire. We CAN use SE, but I have always just prefered pipe.
~Matt
Hack!
The main reason I don't like ductseal is it dries out too quickly. So when you work for me you will have to use silicone.
I have seen dried out ductseal, just never any I've installed, so I dont loose any sleep over it, job security in my eyes.
I'm not talking to you anymore. And you can't be my friend either.
