jjhoward
- Northern NJ
- Owner TJ Electric
Cust has existing underground 200 amp service. He is looking to add about 100 amps of load in a shop by his attached garage. Load analysis for his existing home is 190 amps. (2 large A/C units, elect dryer, elect range, pool)
Presently the underground feed comes off a utility pole on his property about 110' from his house.
Was considering installing a 400 amp pedestal at the pole and bringing a second set of 200 amp conductors to the house. Install a second 200 amp panel and use this 2nd panel to feed his shop.
Question: Is it code complaint (2008) to only have the 2 200amp disconnects at the main breaker panels? These panels will be placed next to each other. No disconnect at the pedestal.
Thank you.
Thank you.
