- San Francisco Bay Area, CA, USA
- Electrical Engineer
Just a little friendly advice on forum posting. You are getting yourself in too deep too fast and mixing things up. You need to slow down and stick to one thing at a time.
1 phase motors, as you described in the beginning, are very different from 3 phase motors.
Using VFDs is very different from using 2 speed motors. You cannot use VFDs on 1 phase motors for the most part.
The only kind of 1 phase motors that can change speed by reducing voltage only are Shaded Pole motors and Universal Motors. For any other type, reducing voltage causes an overload.
If you have "windings" in the rotor of a motor, you either have a Wound Rotor Induction Motor, a Synchronous Motor or a Universal Motor. These are altogether different again from the other things being discussed earlier.
Since this thread started out as a question about a 1 phase 2 speed motor, it's best to finish that out and start a different thread to discuss the other issues, otherwise the responses will get confusing to you since different people may end up responding to different questions on different subjects.
Motor speed is a function of the applied frequency and the number of magnetic poles. 1 phase 2 speed spa pump motors change speeds by using 2 different sets of windings to create two different numbers of magnetic poles in the stator. It's called "2 Speed 2 Winding". In your spa controls then, there is a switch that switches the 120VAC to one set of windings or the other. If you download this booklet, it explains it.
