jmellc
- Durham, NC
- Facility Maintenance Tech. Licensed Electrician
Priced a job 2 weeks ago for replacing Knob/Tube & BX through part of house. Customer kicked around for a week, then called & asked if I could work without permits, as the required smoke detectors & AFI breaker drives the cost up so high. I offered some break if he helps. He still doesn't understand why law requires so much extra work.
Rental house. Insulation ctr could not insulate around K/T. So now, with cost what it is, he is considering not doing it at all. Tenant will suffer higher energy bills & outdated wiring. Insulation ctr & myself may have both lost badly needed work. Customer is out of work, rental is his only income right now. Has to be careful of his $.
Another example of gov hurting more than helping. House could be safer but probably will not be.
