How would you install a bonding grid in fiberglass?
A better question would be, how thick is a fiberglass pad that can support all that weight?
Fiberglass pad, wood deck, what ever the surface, you would still be required to bond it. That is the problem.
As far as the question of "where would the water conduct to?" If you have ever seen kids getting in and out of a hot tub the area gets saturated, this would create a path to earth, water on the pad continuous to the dirt/pavement. Hot tub and Pool water very high in chemicals/minerals that will conduct.
