Resistance is current limiting.
A 1,000,000 ohm resistor in series with a 73.3 ohm resistor(3 amp appliance @ 220 volts) will equal a 1,000,073.3 ohm resistor, and allow only .00021998 amps which is less then without the appliance in series.
Another words: What rattus said:grin:
Yes but is an apliance with a motor really seen as a constant impedance. Or does the impedance of the device change as the load on the device changes similar to a motor? As the blender is loaded and unloaded wont the impedance change.
Take a motor for example that has a changing impdeance determined by R2/s. A motor is a constant power device which will try to draw rated current to turn the load regardless of what other impedance is in the circuit.
So as an example what happens if we put a resistor in front of a motor? Will the motor not try to draw rated current still? Obviously there will be voltage dropped across the resistor and less avalaibe at the motor so it will in turn then try to draw more current. Is this not ture? So in the case of a motor will a resistor in a circuit really limit the current as it would with a constant impedance device such as a light bulb?
