P
Physis 3
Guest
Does anybody have a problem with an inspector being totally convinced that his stupid three light plug in toy will faithfully report a faulty neutral to him.
Jim W in Tampa said:.......but you will cause some problems.
barbeer said:When I use a plug-in tester it is generally to spot check premise wiring and verify GFI and ARC FAULT protection.
ryan_618 said:Plug in "testers" aren't listed for that.
barbeer said:If by "that" you mean able to trip an ARC FAULT device, you are right, they mechanically do not do it.
