Strahan
- Watsontown, PA
Going thru the dreaded home inspection process in order to sell home. A receptacle was called to my attention for having a loose ground. Upon further investigation I believe I know what is causing it just need a little reassurance since I'm mainly industrial mindset. Upon taking voltage readings I found approx 118v from L1-N, L1-GND 60v, N-GND 60v. This tells me I have lost my bond between the GND and Neutral possibly at panel or I don't have complete continuity from recept in question back to panel on a ground or neutral. I'm leaning more towards the GRND being the problem since I'm reading good voltage between L1 and Neutral. Is this correct thinking? Thanks in advance guys!
