you know, there are devices made these days made SPECIFICALLY for Aluminum terminations...
30 years ago, everything used steel screws. that is what caused so many problems with the OLD aluminum alloy.
these days you can replace ALL devices with CO/ALR and for the connections that you cannot use a CO/ALR device, you can use a insulated 2 barrel splice lug (such as those made by Polaris) to do the copper to aluminum connections.
I have read within the last 6 or 8 months that Ideal purple wirenuts had lost their listing or were no longer approved for copper to AL connections.
when you consider the cost of two or three purple wirenuts to pigtail out to copper versus a CO/ALR rated switch or receptacle, i would think it would be better to use the device.
