Mondays Photo : Violations Part IV
480sparky
Iowegia
OK, here's one with a little meat to it. I started a house makeover today, and some other EC had started rewiring it. This is the panel as I found it. I can't tell much more than what's in the photo because it's in the basement and there's no light down there, so I couldn't see anything at all.
This is a reduced and trimmed copy of the original, so those with dial-up don't have to wait 5 minutes to see the 2304 x 3072 pixel original. The original can be seen by clicking here.
peter d
New England
It looks a little sketchy. The orange extension cord is obviously a problem.
But I've seen much worse. At least it's EMT and the wires can be pulled out and redone.
(So yeah, maybe you Chicago guys have a point. :D)
cschmid
well at-least they spaced it off the wall..to bad it does not clear the stud face. you get some free wire nuts with a built in shelf..the wire nut ads some personality to the panel.. the grounds are effective too..
cadpoint
Durham, NC
The Organge matchs the Red of the Red/Yellow wire nuts ?
lol, I was going to ask is that the new color ? But do tell them to buy a dehumidifier ...
cschmid
homeline you get what you pay for.. I have seen all to often in a homeline a breaker tripped and no handle movement had to take dmm to find bad breaker..you know proper labeling and everything..
RUWired
Pa.
I spy a violation with the GEC.It should be attached where the connection is made when a screw is used to make the connection.When its a wire or bar its allowed to go either the ground bar or neutral bar.(250.24(A)4).
Rick
