walkerj
- Baton Rouge
massfd said:Has anyone installed a 6 or 8 circuit Generac transfer switch. They come with a prewired whip that contains hots out from the breakers on the original panel and hots returning from the 6 or 8 generac switches. Only 1 neutral in the whip to be landed on the original neutral bar. The original branch circuit neutrals remain in the original panel.
Is this not the same as the OP's question about a sub panel 12 inches away.
How do these things get approved, I see them all over the place. Better than backfeeding a breaker but does not comply with the NEC as quoted by others.
This is compliant because the electromagnetic fields cancel each other out because they are moving in two different directions.
All it is is a switch loop
