I am sorry for beating a dead horse with this topic.
My point with all this is this:
I follow the Code as much as I can. Sure I might miss a code rule here or there, especially when an installation hits several different code rules. What I find is that the Code tells me what I can and cannot do.
Sometimes there are items such as this topic, that we are not told that we can or cannot do it. In this example, nothing in the code tells us that we can use MWBC to feed both 240V and 120V loads on the same circuit. Then again, nothing is telling us we cannot do it either. Somewhere between Exception 1 and Exception 2 we have this void that doesn't address combined loads. You can't possible tell me that the wording in those exceptions tells me to wire this way. You may argue that it is ALLOWED, but I will argue that it is NOT allowed.
So where should things fall?
Some argue that if the NEC does not tell me I can't, than I can.
Some argue that if the NEC does not tell me I can, then I can't.
I know most installers will lean towards the first, and most inspectors will lean toward the second. That is the nature of the beast.
As for the Handbook and Mike Holt's graphics and wordings. These are interpretations. Yes, the Handbook is made by the NFPA people. Yes, Mike is incredibly knowledgeable in the NEC. But these are not Gospel, but rather interpretations. Don and Jim are correct with their statements about the Handbooks. They may think I am all wet on this issue, but they are correct on Codebook vs Handbook.
I would love to hear your thoughts, all of you, including Journeyman, Master, Inspector and Engineer, on my question of where should things fall.
I would like to see Mike's justification for wording his Exception 2 like he did in his graphic. That wording is not the wording in the NEC, and would have needed some kind of supporting code rules or something else to make that assumption.
