In the past when wiring in a residential garage with a block wall up to about 9 ft I will sleeve the romex in pvc conduit just till it reaches the rafters.
How do you usually do this......strap nm to block wall or sleeve in pvc.
Some will say that you can run nm in pvc. Ive never had a problem with inspectors....probally because its inside the building.
Just currious what others do.
