russ in post #31 said:
On some remodels or revisions location often is a problem that requires allowances.
This is a new building, and design is not exactly and inspectors big worry. I'd tell them to spin the panel around and let it face in to the room.
Brian, I assume your in plan review stage. I'd tell them to turn it.
You want him to turn the panel to face into the bedroom ? . Talk about ugly ! . I can imagine the reaction of a woman to that. . If I think it's nasty looking, I know it would be twice as bad to a woman. . Do you think you have even a small chance of getting that past the woman of the house ?
georgestolz in post #36 said:
Deron, welcome to the forum.
I think that a luminaire is a constant source of moderate heat.
A panelboard could be a source of extreme heat during a fault. That panelboard could sit there behind the rod with clothes packed up against it forever under normal conditions will no ill effect, true.
But now cast a flash out the face of the panelboard on a combustible shirt...
The dreaded arc flash.
deronmoped in post #37 said:
Thanks for the welcome, happy to be here.
Why would the description of a storage area in a closet only apply to lights, does the definition of the stroage area change when there is a subpanel or any other electrical item in there? My understanding of a description is it applies in all cases.
I will agree that a panel that has no covers on it and has a major fault occur could start a fire if it is close enough to combustionable materials. But, why does the code go into so much detail about a closet and the location of a light if a lights are only moderate sources of heat? I'm thinking these lights in closets were and still are (if not installed properly) a big problem with fires.
You?re getting close to hitting on a major issue when you say: ?a panel that has no covers on it and has a major fault occur could start a fire if it is close enough to combustionable materials.?
deronmoped in post #39 said:
I actually would think a closet would be a better place to have a exploding panel. I mean would you rather have it next to your bed as you are sleeping so you can get sparyed with molten metal and plastic? Would you want to be the combustionable? Panels are installed in bedrooms all the time, if they are such a problem and a source of fires would you want your inspector saying "The babies room is a perfect location for a fire to start." NOT!
You started to address the major issue in post #37, before but then you missed it. . I don?t think panels explode while people are
sleeping but there is a serious arc flash issue when
working on electrical equipment. . Most equipment can be deenergized for servicing, but panels are the leading category of equipment that is worked on hot. . The calorie energy available at many commercial panels is so high that protection level designation, based on calories available, is required to be ?field marked? [110.16] on non-dwelling unit panels. . Residential projects might have less energy available to a fault explosion but those working on those panels are rarely ever properly protected and commonly have untrained workers and homeowners sticking tools into them.
You?re not in ?your bed as you are sleeping so you can get sparyed with molten metal and plastic?. . The panel cover is off and the tools are out and the fault sends a ball of flame into you and into the room. . If it?s not bad enough to be burned by the fire and blinded by the flash, your cotton Tshirt continues to burn. . But what if it?s not just the Tshirt burning ? . What if the entire combustible contents of the closet is roaring around you while your still blinded ?
Even an uneducated homeowner would most likely move a gas can away from a panel in the garage before working on it. . But how many people would take all the time needed to empty a packed closet before sticking their hands in the panel ?
deronmoped in post #41 said:
I just thought of something else, lets go by what some guys are saying, take "such as in a clothes closet", are you guys going to stick to what it says, or are you now going to redefine that sentance? It says "such as in a clothes closet", so as I read a set of plans and it says closet, not clothes closet, then a panel is ok in a closet. Or if the plans say a walk in closet, then a panel is ok there too. Does a set of plans have to say "Electrical closet" before some will say it is ok to install a panel?
When is a closet a clothes closet, are all closets clothes closets, are clothes closets allways in bedrooms. At some point a inspector will have to decide where it is ok to install a panel, because if he "only" uses the definition of "such as in a clothes closet", then is he going to say ok to all other closets.
Say you have a set of plans that shows a bedroom with a small closet, next to that bedroom is a hall and in this hall there is a large walk in closet. On the plans all it says is "closet" for both, it does not spell out a clothes closet. The electrician wants to install the panel in the large walk in closet, is it ok?
Deron.
That?s a judgment call. . But I think it?s best to have some clear guidelines so that there won?t be variations of application based on the mood of the inspector or relationship with the contractor. . Also clear guidelines allow the contractor to know and be ready for inspection.
In my opinion, I use 3 criteria for deciding.
A closet in a bedroom is a clothescloset.
A closet with a bar hanger is a clothescloset.
And finally a closet that?s designated as a clothescloset is a clothescloset.
David
