tonyou812 said:Senior Celtic I was wondering when you would chime in?
I was reading the news at www.nj.com
I have yet to do a service upgrade where there were any existing ground rods already installed.romexking said:Tiger,
pretty nice site. I like it that you have enough concern for your customer's safety to install new ground rods instead of taking the easy way out and using the existing. That little extra step says a lot about you and your company.
The hammer was the only tool I needed for this job and I rented it from the homeowner.celtic said:I noticed it too...truly the mark of a hack to use the HO's tools.
Tiger Electrical said:I'd take the time to explain my service upgrades but it's easier to send you to my website. The 100A "before" picture was a panel change-out without changing the service cable or grounding. My services have exterior IMC and always 2 new ground rods. I never trust previous grounding. This 100A service was about 30' from the meter, so is a disconnect type. I moved the panel to a wall with better access. The old panel was buried in a corner that was their prime storage area, so I had to run conduit to J Boxes for the branch circuits. This one took a little longer than 4 hours. So did the double on the same Picture Page.
Dave
www.TigerElectrical.com
emahler said:nice dave...i like the add on surge protector...the upsell with squared qo....but one question, why is it common in Chicago to put all the receptacles sideways like that?
emahler said:why is it common in Chicago to put all the receptacles sideways like that?
peter d said:That's popped up a few times here before, and the only conclusion I can some to is "local tradition."
It's so they don't spend all their time arguing about wether the ground should be up or down.emahler said:nice dave...i like the add on surge protector...the upsell with squared qo....but one question, why is it common in Chicago to put all the receptacles sideways like that?
emahler said:that's why i'm asking a guy from chicago and not a guy from taxichussetts....
aline said:The real question is why do most of us install them vertically?
You have to penetrate the roof twice.electricguy said:This one was a bit of a PITA as there wasn't much room for proper meter height so the mast is beside the meter socket and the riser is EMT. the mast is bolted to the structure in 3 places. the riser is strapped with lag bolts.
Thats assuming you install them with the ground down like any normally sane electrician would do.emahler said:because that's the proper way to make a smiley face
emahler said:why didn't the EC install conduits underground for phone and cable when they dug up for the service?
