Jim W in Tampa
- Tampa Florida
So if my light fixture for this garage is a plug in shop light how can i use it without the receptacle ?
Jim W in Tampa said:So if my light fixture for this garage is a plug in shop light how can i use it without the receptacle ?
roger said:You can use it, but the receptacle will have to be in addition to the rerquired "lighting outlet"
Remember, you can put a blank plate on the lighting outlet, but it must be there.
Roger
infinity said:So a garage with a low bay HID light plugged into a switch control receptacle wouldn't satisfy the lighting out requirement for a detached garage?
Jim W in Tampa said:Ok so i remove receptacle and blank it and its now legal ?
electricmanscott said:Is there a lighting outlet requirement for a detached garage?
Is there a code section on this? I'm having trouble finding it. Thanks.buckofdurham said:Just thought I would through this in. 2008 code says if both top and botton of a duplex outlet is switched then it does not count as a required outlet.
Okay, so install a round ceiling box now, put on a keyless, and come back later and replace it with a round plate with a receptacle in it.roger said:Remember, you can put a blank plate on the lighting outlet, but it must be there.
LarryFine said:Okay, so install a round ceiling box now, put on a keyless, and come back later and replace it with a round plate with a receptacle in it.
rcarroll said:Is there a code section on this? I'm having trouble finding it. Thanks.
Yeah, I don't have a problem with a switched recep used as a lighting outlet. In post #13, buckofdurham stated that if both top & bottom of a recep. outlet is switched, it doesn't count as the required outlet. I am curious where that code is.infinity said:Look at 210.52(2) and 210.70(A)(1)Exception.
rcarroll said:..... In post #13, buckofdurham stated that if both top & bottom of a recep. outlet is switched, it doesn't count as the required outlet. I am curious where that code is.
rcarroll said:Yeah, I don't have a problem with a switched recep used as a lighting outlet. In post #13, buckofdurham stated that if both top & bottom of a recep. outlet is switched, it doesn't count as the required outlet. I am curious where that code is.
Call me stupid! I get it now. Duh:grin:infinity said:Did you take a look at the Article(s) M.D. and I posted?
roger said:No, you don't have to remove the receptacle, leave right where you want it to be, but be sure your unused lighting outlet is covered. :roll:
Roger
infinity said:Here's the definition of a lighting outlet:
Lighting Outlet. An outlet intended for the direct connection of a lampholder or luminaire
Do you think that a switch controlled receptacle meets the definition?
These are listed combination devices that codes intent seems to be to be sure that the hot is not connected to the screwshell. If the intention is to plug a 1x4 flourescent in the future I dont see a V here. When the fixtures come in just unscrew the lamps and plug the fixtures in.iwire said:Not sure if that is OK.
Take a look at 410.47.
'Lampholders of the screw shell type shall be installed for use as lamp holders only'
quogueelectric said:These are listed combination devices
