same idea with a 3 phase transformer. the old single phase pots had the secondary windings in series and tapped a neutral from the center. with alternating current, as line1 is "comming" line 2 is "going". single phase.
Sez who? It is a matter of reference preference said the poet know-it.
The physics of the voltages present and the names we use are not always consistent. We have reserved the name "two-phase" to mean the 90? quarter-phase system. We call the 180? system single-phase.
The names we choose do not change the physical nature of the voltages. You can't always perfectly match the naming conventions we use to the physical system, so ultimately you have to say it is called what it is because we choose to call it that.
I contend that we should stick with the conventional names we are all used to or we will create confusion. But, for those that desire a more complete understanding, we should also recognize the physical nature of the systems involved. Considering most of what we deal with in the EC world, most people could care less about the physics of the system.
From a broader scope of things, if we ignore the physics as the ultimate reference and let the names be the ultimate reference, we will be trying to constrain the physical system to the description given by the naming conventions. The naming conventions we use are not consistent across different physical systems and therefore can't be the ultimate reference for the nature of the physical systems.
In other words, by convention we call the 180? system single-phase. And this name describes almost everything we will encounter. However, it is incorrect to say that there are not also two different phase voltages present. It just so happens that in this particular case, the single-phase configuration and the two-phase configuration have exactly the same EMFs.
Handbook for Electrical Engineers-1917
Strictly, the so-called single-phase system is a star-connected two-phase system, since the currents from the two terminals are in opposite directions at any instant, the current leaving by one and entering by the other. However, in practice the name two-phase system is used for a system supplied from a generator or other source of e.m.f. having two windings in which are developed two e.m.f.'s differing in phase by 90?; i.e., a two-phase system is in reality two distinct single-phase systems each with two terminals.
note: the star connection referenced is a common-point connection like a wye as opposed to the mesh connection or end-to-end connection like in a delta
