weressl said:
It is all of our duty to protect others from danger, eg. the HO where his work is being done exposed to unsafe electrical installation. The question remains: do you KNOW if his work is unsafe? Just because he is not licensed by the State it does not mean his work is not right.
First off can you say the work is safe. Would you be willing to sign off on it. Would you be willing to take responsibility for it sight unseen.
If we lived under a Theocratic government with and ecclesiastical court system morals might figure into it but we don't we have a democratic goverment with a secular court system. We have a system of laws for almost everything and with good reason.
With our legal sytem it's not up to each of us to run around playing God and making calls on the work of others, that's what laws are for.
With our system in place tonyou812 doesn't have the authority to say if the side worker's job is safe and in cases doesn't have the authority to say if his own work is safe. He just doesn't get to make the final judgment call. There is a system in place to make sure the work is safe which tonyou812 follows and the side worker doesn't. The final authority rest with the AHJ and not with the Pope, priest, preacher or any other religious authority.
I doesn't matter if the work is safe or not it's still illegal because
it's not possible to know if the work is safe. It doen't have to be unsafe, just
questionable. It hasn't recieved
approval by an unbiased party ( those without motive to cut corners).
In a parable written a couple thousand years ago a wise man stated " render unto Caesar that which is Caesar's and render unto God that which is God's". Electrical work would seem to fall into Caesar's jurisdiction ( civil authority).
This is a
legal issue and it's impossible to say if the work is safe without going through the proper inspection procedure. Even for a licensed elecrical contractor the work is not considered safe until inspected by those with the authority to make the ruling. That's why there is both a rough and final inspection to allow the authorities to see the work in progress when it it possible to make such a judgment call.
