Have a 3-phase, 208 v, 3 HP motor.
It is currently setup with typical motor starter/fused disconnect with forward/reverse contacts and thermal OL's.
A direction selector switch (non-latching) is located on the side of the unit.
The customer wants to set it up with a VFD to control the speed, minimize the sudden jerk of starting and stopping.
I don't have first-hand experience. I understand how VFD's work, but have questions about getting it setup to do what the customer wants.
I plan to leave the existing motor starter box where it's located and mount the VFD in an adjacent box with a nipple between the 2 enclosures.
-I'm assuming that I'll by-pass the existing contactors and re-route the conductors (load side of fuses at disconnect). Does a typical VFD perform OL functions, or do I have to continue to use the existing OL's?
-they want controls mounted to the side of the enclosure that will allow the operator to choose the direction (forward/reverse) of motor and the speed.
My understanding is that the speed is controlled by some sort of potentiometer, typically does each manufacturer provide a potentiometer for their VFD or are there "universal" potentiometers that I should look at choosing?
-how does the operator select the motor direction? I.e., what sort of button setup should I be looking for?
-I'm sure the customer will want a display of some sort that shows which direction is selected before using the potentiometer to operate the button.
These are all fairly basic functions, I know how to do this with your typical motor starter setup. I just don't have experience with VFD's.
Thanks for any basic info/answers!
