So common most people have more than one as the first one melted or caught fire so they had to buy another one.
Why? The 15-a receptacle should not have a 30a OCPD on it.
Without the twistlock style end, these are quite common with people that have RV's
According to NEMA, there are (5) Manufacturers of Weatherproof Receptacles.
If you need some immediate gratification I did a Google Product Search for Weatherproof Receptacles
Yes, and if you go to any of those manufactures sites you will find them called and listed as 'resistant' not proof.
Actually, our (Hubbell) Pin & Sleeve devices are classified as "Watertight" per IEC 60309-1 and have IP67 Suitability.
You know what, forget it. I was trying to get folks to learn to use the correct terminology but the heck with it. Obviously I am just an idiot for trying. :roll:
They are resistant to proof.Yes, and are those the type of devices the OP was asking about or the kind the NEC requires?
This picture has a 15-amp male plug connected to a 30-amp female. If I was a manufacturer, I think I'd have a self imposed problem selling this.
see previous :I don't understand the issue here:
according to the NEC definition in article 100, the receptacles you are talking about are weatherproof, right ? so why wouldn't you use the correct NEC term "weatherproof" ?
Not my point.... :roll:
~Matt
see previous :
It just seemed to be the reason iwire took issue with "proof". It doesn't matter to me one way or the other.so in every other case, you guys want to use NEC definitions and NEC terminology, but in this case, just because manufacturers are calling them weather resistant, you have decided that the manufacturer terminology is correct ? I don't see the logic.
