76nemo
- Ogdensburg, NY
jdsmith said:I bought the 1587 a while back because I didn't have time to wait to order one and that was the only one in stock. I would probably prefer to have the 1507 or the other non-DMM unit because of the PI and DAR calculation. Strangely enough, I don't know if I've ever used the test lead with the button on the probe, I usually use a pair of grabby clips on the end of my test leads. I've probably used the DMM features a couple times, and I know it's saved me carrying a duplicate meter on a few occasions. It's always worked fine but I haven't really used it enough to give it a thorough review. Probably had it 6-8 months now.
That's the problem with marketing. It seems the 1587 is the king of the hill, and may be labeled rightly so as a sole meter. It is a full fledged DMM with the low-pass feature for working with VFD's, it has temp. function as well, but it is more suited as an "one and all" meter. I have had alot of people complain that the the 1587 wasn't exactly the top of the line. The 1587 is the top of the line as far as a "all in one" maintenance meter, it does not have the "Compare" feature, or the PI/DAR function, nor the low-ohm bond measurement. The 1587 may be the ultimate maintenance DMM, but it is a DMM, not engineered as a Megohmeter.
As we have all once said,.. "You can't have it all."
