Power Tech
- Lebec, California
Is it legal to stab #14 wire in the back of a receptacle or switch per NEC?
Solid only, I believe; the OP's user name suggests to me that he MAY be pulling stranded.Yes. Section 110.3(B) of the NEC.
If it has the means for it, and generally they only allow for #14 solid copper.
But I wouldn't recommend it - 90% of the service calls I go on where someone is reporting a section of lights and/or plugs in their house that stopped working, it usually winds up being a receptacle or switch with a back-stap connection that went south. I don't trust them and I always wrap the wires on the screws.
90%? don't go on many service calls?
lol... no, 90% of the service calls in which someone is complaining about a section of lights or plugs failing. Not 90% of the service calls altogether.
Those are rough statistics too, by the way![]()
Why spoil the fun of letting someone spend hours trying to get stranded wire into a back-stab recep?
And I seem to be in the small minority of persons who have never experienced a problem w/ back-stabbed connections; not with my work or anyone else I've gone behind.
All of my 14ga installations are back-stabbed.
really, really rough...
Most of the ones I've seen are older... 10 years or more maybe. Some older plugs don't even have a side-wire option, they're stab-in only.
. . . Some older plugs don't even have a side-wire option, they're stab-in only.
10 YO and older would accept 12. I think the requirement to allow only 14 was in 2000.
Really?
We were purchasing devices that accepted #12 back-stabs well into 2005-06 when I was an electrician for another company.
When the supply house started stocking devices that only accepted #14, my boss at the time finally decided that was enough to start using #14 everywhere allowed on resi work.
Oh. Well I was talking about receptacles.![]()
...When the supply house started stocking devices that only accepted #14, my boss at the time finally decided that was enough to start using #14 everywhere allowed on resi work.
I saw one old salt rebel against the #14 limitation. He actually drilled out the holes in the back of the new devices so that #12 would fit in there ...![]()
