- Massachusetts
And if I am on a hot roof 10 floors up, I want to be the one to decide if I should just burn the drill up and finish the job
I sure agree there.
I can certainly understand balking at the cost, but for what basis do you have for saying it won't "cut it"? Did you assume that the drill has less torque than the others? Did you assume that it was larger than the others? Did you assume that it was less versatile than others? You would be wrong on all counts, and I have examined them all--that was my job.No knock on a nice tool, but this drill doesn't cut it for most electricians.
Really? So it is worth it to you to destroy a $200 drill, plus the labor costs of going out to buy a replacement? I doubt that, especially if the drill were to get toasted before you could even finish the task at hand. You could probably afford to keep this stance if you had a dozen $20 Wall-Mart drills in your truck, but since most cordless drills are in the $200 range, I don't think it would be the best stance to take. Wooden step ladders are cheaper than fiberglass, so do you have a fleet of wooden ladders in your arsenal?(And if I am on a hot roof 10 floors up, I want to be the one to decide if I should just burn the drill up and finish the job or go get a different one). JMSHIO
And if I am on a hot roof 10 floors up, I want to be the one to decide if I should just burn the drill up and finish the job or go get a different one.
I'll agree to a point, but I'd never climb 10 floors with a cordless tool without the entire case with charger and spare battery.I sure agree there.
On most drills, if you left them sitting out in the hot sun, their internal temperature would easily shoot up above 120 degrees before use, and when you used the drill, you would damage the motor and battery. The Festool drill monitors temperature and would not allow you to damage the drill even if you tried.
Well of course! I wasn't saying the drill is mamby-pamby, only that it protects itself from permanent damage. You can push the drill to its limits, but the difference is this drill knows what its limits are and prevents you from causing permanent damage.No ........ if in fact that once in a while time I need to push destroyed t immediately but it does not.
I actually get quite good life out of all my cordless tools, a big factor in that is how I use them ............ but when I decide I need to push the tool I don't have any desire for it to bail out on me. To me that is not a tool worthy of having.
Likely the biggest reason for all these peoples drill failures is straight out overload.
By the way, when I said that the drills shut down to protect themselves, I think some of you were thinking that this is a permanent shut-down. It is not. When you release and re-engage the trigger, you reset the electronics. This isn't like a non-intelligent bi-metal thermal reset where you are stuck waiting several minutes for a reset. It is computer controlled, and if you don't repeat the same overload, the drill will resume normal operation. It may shut down if you are trying to drive a massively long lag screw, but you can instantly switch over to redrilling the pilot hole that caused the overload. There is no delay for a reset.Well yeah but from the sound of it the other batt would not help because the drill shut down
Oh, as a follow-up, no, this is not correct. If the drill shut down to protect the low battery, you can continue to use the existing battery for normal operations of both drilling and screwing. It shuts down because you tried to take more power out of the battery than what it can safely deliver, but that does not mean it can't be run at all.Well yeah but from the sound of it the other batt would not help because the drill shut down
Did you assume that the drill has less torque than the others? ?
No, that is not true. You are accustomed to seeing inefficient brushed-DC motors in cordless tools, and I assume that this is the first time you have even heard of a battery operated tool that uses a 3-phase motor. If you pull the motor out of your favorite drill, you can bet that the winding wire will be a lot smaller than 0.030" (20 ga), and that is single-phase. This is a 3-phase motor, so the current per phase for comparable power will be sqrt-3 times smaller. As I said earlier, this is a custom built motor just for this drill, and is not an off-the-shelf motor.Yes. I really do assume that....is that not true? This drill does not look like it can but a 1" auger bit through 4 studs or a 1" step bit through old steel. It looks like the kinda tool a cabinet guy would use (they are a very carefuly sort).
Maybe I am wrong...I've never actually used one.
Now I am on my second 19.2v Craftsman drill, it has a 1/2 chuck and hammerdrill function, I have been using it for 2 years and It cost me around 99 dollars, I believe it is made by Ryobi. It gets the job done, and nobody seems to want to walk off with it, and if it does get stolen or I drop it off a scaffold and it breaks, it wont break the bank to replace it....
"Very impressive, Mr. Kotter!"
Nemo, you are not only killing your batteries but probably also damaging your motors. The more you use a battery the more heat it produces. The longer you need to charge the battery the hotter it gets. Heat is the killer of batteries. Run your batteries until they no longer do the work you want them to do and then recharge. Your batteries and tools will last much longer.
Yeah, well up your nose with a rubber hose! :grin:"Very impressive, Mr. Kotter!"
By any chance is this a LiIon battery? I can't remember the details at the moment, but I believe high temperature during the charging cycle is what causes the runaway effect with the lithium, and as we have all heard, is why these batteries ignite. New battery chemistries are helping to reduce this, but it is still critical to closely control the temperature when charging.As far as the temperature shut off functions go there's one problem I see with them. My charger shuts down when the ambient temperature reaches 104?F and has no built in fan. I don't think I have to say that such a low temp. can be an issue in the summertime.
"In yer ear with Rosie Greer!" (Whatever that means.)Yeah, well up your nose with a rubber hose! :grin:
