iMuse97
- Chicagoland
what are post tension cables and what happens if they get hit?
cables in the concrete for strength that are tensioned after installation and pouring and curing, unlike rebar which just stays there.
Use a hilti gx 100 or gx 120 Gas operated track fastener is extremely fast as fast as you can pull the trigger it fires. We also used to use the ceiling pole powder actuated tools with a washer and tiewire long enough to strap about 10 cables every 6 ft for mc cable.I am running MC fixture to fixture in a drop ceiling with a concrete deck. I dont want to tapcon the mc with one holes to the concrete deck but I cant think of any other way to support the MC. The ceiling isnt up yet so I figured i get ahead of them. I thought about when shooting my fixture supports in the deck for the fixture tie ups maybe shooting extra to tie the MC to. Figured Id ask for some other ideas.
for single runs I would stick with a pole gun, if powder actuated then yes you must be licensed to use it, however they make CO2 actuated that you do not have to be.
who do you get licensed with? I dont really understand having to get a license for a hand tool.
Wow! A corn-on-the-cob hanger.
Is that the same as pre-stressed concrete? I remember years ago working under a guy who cut a cable core-drilling a floor. You could hear the "twang!" all through the building. I don't remember ever hearing anything about repairing or replacing it.cables in the concrete for strength that are tensioned after installation and pouring and curing, unlike rebar which just stays there.
http://en.wikipedia.org/wiki/Prestressed_concreteIs that the same as pre-stressed concrete?...
Not bad recall... but it depends on size of wire or other being attached to. And they do make smaller... K8 and KXLets see if I remember- Caddy k12 for 1/2" pipe. I don't know if they make a smaller size for 3/8" diameter cables but I bet they do.
I think this was the last kind, the unbonded post-tensioned cable. It was not just a thud.http://en.wikipedia.org/wiki/Prestressed_concrete
I wouldn't think you'd hear a "twang" with pre-stressed. Perhaps a thud if the cable gives abruptly.
I would think just tapcons and one holes would be the fastest, I dont know about cheapest though.
