But what is one to do when the engineer totally disregards what your pointing out and insist that your wrong. Then tells you that, unless you install as per his specs, he will refuse to sign off on the project?
muckusmc,
At that point if I were the EC I would document your difference in opinion, and copy folks associated with the job, including the POCO.
Depending on the construction process that might take the form of a Request for Information. Or if it's more informal, perhaps an email to all parties concerned.
You could also file a complaint with the Engineering License Board for the State in which the job is being installed. I'm on the DE Association of Professional Engineer's Law Enforcement and Ethics committee and if an electrician (anyone) were to file a complaint against an engineer for any reason, the complaint would be promptly investigated and all parties may be contacted for resolution. Hopefully it wouldn't come to that, but if the engineer were incompetent and unwilling to discuss the situation, there's always that complaint option.
I know from my experience that a good engineer maintains working relationships with all parties involved to avoid problems.. from EC to POCO to GC to plumber to carpenter.....and on and on...
Good Luck!
John M
