knoppdude
- Sacramento,ca
I don't know if this question has been asked before, but does anyone know why the service neutral conductor for a residential dwelling is sized by dividing the calculated VA for the neutral load by 240 volts instead of 120 volts? I ask this because the VA load for the neutral load is determined from 120 volt loads, and because it does not seem that the neutral would ever have 240 volts imposed on it. The answer is probably obvious, but I am not seeing it. Thanks.
