dpeter
- Indianapolis, In.
- elevator mechanic / building maintenance
How is the drain wire or alluminum ground wire on ac cable dealt with? Do you treat it as a ground wire and connect it to the box and or device and if so how do comply with all of the requirements of al to cu connections or is it to be cut off flush with the jackect and let the connector be the compliant gound path? Seems unnatural to leave a wire unterminated in some way.
