kbsparky
- Delmarva, USA
I would "never" not run an egc--regardless. NEC is minimum code requirements.
We do not install an EGC when installing EMT in metal structure buildings. Each box, and piece of conduit is solidly attached to the grounded steel structure. Installing a separate grounding wire is a complete waste of time and resources in such instances, IMO.
But, when we have EMT installed in a wood framed structure, where the conduit is not attached to solidly grounded surfaces, we will install a supplemental grounding conductor.
Make sense to you?:roll:
