chris kennedy
- Miami Fla.
- 60 yr old tool twisting electrician
How do these things work? Why don't they beep on a grounded conductor carrying a load?
I think they do (?)
Because they respond to voltage above earth, not current through the wire.Why don't they beep on a grounded conductor carrying a load?
The capacitive voltage sensor works because when you
hold the barrel in your hand and place the tip near a live
conductor, you are inserting the high impedance sensing
element into a capacitively coupled series circuit. As in
the previous example your hand and body form a
relatively large capacitor coupled to the floor.
Nope, only above earth.So they don't work on buried cables?![]()
Extech does have a current sensing stick, the only one I am aware of:
http://www.testequipmentdepot.com/extech/electricaltesters/dva30.htm
