I have the loads as balanced as I can on the delta side
A phase 43 B phase 39 and C phase 46.
On the Wye side A phase is 64 b phase is 110 c phase 86..
when you add them up the total are close +/- 1 amp.Everything I have been tought about transformers says if you have 50A on the low side you should have 25A on the high side. This not the case here
Could harmonics from the balasts have something to do with it?
