1793
- Louisville, Kentucky
- Inspector
I sent out a few PMs on this subject and it was thought that the folks on the forum would be interested and helpful so here we go.
Wiring method is NM.
The electrician mistakenly took out the original feed to the Garage and to "fix" his mistake he took and existing 3 wire and reworked the connections to the following: took the red, and connected to the Hot of a lighting circuit to feed the Garage, took the black and used as a switch loop to a light and finally he took the white and tied it to the grounds in the switch box in order to get a Neutral for the Garage circuit.
My concern is being able to point out to HO and the GC who hired the electrician who did this the possible hazards associated with this setup.
Thanks to all and I look forward to your help.
