Further clarification of neutral
Larry, i read the link you posted directed to Dennis and it helped. However,
I'm still a bit confused as to current returning on the neutral. So for example, if I take my voltmeter and apply both leads to an energized 120V receptacle I will read 120V. How much of that 120V is returning to the source on the neutral and when?
Also, in that earlier post you said,
"Originally Posted by Dennisc
I guess a neutral would be like on a 220 v 3 wire hot water heater. Black and red hot, then white neutral. Sound Right? This type of "neutral" is what would handle the imbalance.
Dennis, you just happened to pick the wrong type of appliance as an example, because a water heater uses the two hot wires only. The heating elements are rated at 240v, there are no 120v components in a water heater, so a 2-conductor + g. cable is appropriate.
Now, a clothes dryer is the perfect example, because while the heating element is rated at 240v, and connects line-to-line, but the drum and timer motors are rated for 120v, and connect from one line conductor to the neutral. A 3-conductor + g. cable is called for.
So, for a dryer, both lines would carry the heater current; in addition, one of the lines and the neutral would carry the motor loads. If the heater is 20a and the motors total 5a, then one line would carry 20a, one line would carry 25a, and the neutral would carry 5a."
__________________
Code references based on 2005 NEC
Larry B. Fine
Master Electrician
Electrical Contractor
Richmond, VA
In the case of the 240V appliance with no neutral, how do the electrons flow back to the source?
Mka,
LU 595, apprentice
