Me vs. the customer
Mr. Wizard
Texas
Did a service upgrade today. Everything went smooth, passed inspection. While waiting on POCO I ohmed my circuits, all ok. Panel gets energized, I turn on the main, then branch circuits one by one, all ok. Homeowner comes out and says her TV isn't coming on. I go in and verify there is 120 on the recep. A cable box is plugged into the same outlet, and it's on. She, after a rant, tells me I fried her TV. She then takes the TV to the local barbershop/cd retailer/TV repair shop, and comes back 20 minutes later with the diagnosis of "there was no ground on the TV when the power was restored, so it fried the TV." Huh? If her TV (built in the late 90's, and by the homeowners own account, stays on 24 hours a day) would have fried, then the cable box and anything else on that circuit would have went up in smoke too. I remained very polite and cordial to her, but I feel she's going to run this one in the ground. What would be my recourse, or how could this best be handled? Thanks
nakulak
buy her a new tv.
in the future, tell homeowner to unplug all electronics prior to you getting to the job, add disclaimer to your proposal indicating this..
mivey
I would have to have a talk with the repair shop and have them explain it to me in front of the customer. I would feel sorry for the repair shop if they repeated the same story then.
I'm not so sure you got the full story from the repair shop.
Mr. Wizard
Texas
buy her a new tv.
And I would do that in a heartbeat if she (or someone) could explain how it could have happened
Power Tech
Measure it and go to Walmart and buy her a TV. Obviously, by the actions you described this is staged (she's a liar). Your out $150, that will seem inexpensive if you take the battle road. Been through it -- You will not win. Proceed with great caution. And, get the check!
Power Tech
There 's no repair shop.
Call her bluff. I dare you.
jaylectricity
Massachusetts
licensed journeyman electrician
And now I'm sickened by some of the responses in this thread.
How would upgrading the electricity in the house cause a television to have problems?
Buy her a new TV?
NO WAY!
Cow
Eastern Oregon
She most likely won't pay her bill no matter what, she just sounds like that type of person. So now you want to add the cost of a tv to it?
If the little cable box isn't smoked, there's her sign.
JFletcher
Williamsburg, VA
" her TV built in the late 90's..."
I'll assume that her TV isn't enormous if she moved it by herself to a repair shop and back in 20 minutes.
I'd buy her a used TV. CHKD or DAV, ~$50, problem solved, lesson learned.
Mr. Wizard
Texas
It's just a little 20" picture-tube TV. I really would get her a TV (a used one) if I honestly felt that I caused her old one to go out. But this was my second visit, and neither time did I see the TV on. The cablebox was fine, and there were no complaints about anything else not working. I personally beleive she trying to scam me. If I run out and buy her a TV, it'll put the fire out, but if she is scamming me then she would have succeeded in ripping me off :mad:
JFletcher
Williamsburg, VA
I don't think you caused her TV to fail (my gut tells me the same it tells you: it was broken before you got there), and you're right, if she's scamming you then she is ripping you off for ~$50. If it were a more high-ticket item, say a 60" plasma 1080 or a new $4k laptop, I'd put up more of a fight, you bet! Or let my insurance eat it if it came to that.
In this case, I think the time you will spend (waste) arguing/dealing with her will be worth more to you than the TV is, ripoff or not.
okeefe
Albany New York
Somebody tell me how the tv would not work after the service upgrade, but the cable box stills works. Did you plug the tv in to see if it works? Where can a person bring a tv in for service and have it looked at so fast with an answer? The story does not make sense. I would not want to buy her a tv, and not sure that I would buy one, because if you do then she will call next week and ask for something else.
