macmikeman
- Planet macmikeman
The title is mechanical execution of work. If you are killing those circuits via a mechanical means, then it applys.:grin:I'm with Celtic. How does 110.12 apply to abandoned conductors?
If the inspector can't find a real code violation and has to use 110.12 for a "safety reason" either the inspector has no idea what he is doing or there is no real safety issue.I think people on the board already notice that we a little bit of from the original question. The answer to is provided in 372.13
I respect healthy arguments and conversation.
It was a pleasure talking to you my friend. Believed me: The reason behind 110.12 being in the code is only for the safety reason.
I am sure i do not have to explain that
Even the NEC Style Manual says the wording used in 110.12, "neat and workman like" is vague and possibly unenforceable.
BTW, As someone said, I'm all for labelling wire for future use. Or send it to Larry.
Then I will create nice neat coils of capped conductors, labeled as abandonded. That meets the undefinable neat and workmanlike I think.The title is mechanical execution of work. If you are killing those circuits via a mechanical means, then it applys.:grin:
Then I will create nice neat coils of capped conductors, labeled as abandonded. That meets the undefinable neat and workmanlike I think.![]()
What if I drive there for local pickup, like some eBay sellers allow?I think we should ALL take Larry up on his offer...stripped and cleaned...but COD![]()
An auto repair shop, 200 amp panel 10 or so risers with no offsets, strut. Just pushed back to the wall with a big bow and 1 hole straps. In a concealed space maybe but this is exposed work.
Oh, the old 'Bow and go' method of running raceways. I am no supporter of that method, it looks bad in my opinion but the only question an inspector should consider is this one.
Did it conform to the NEC or not?
If yes it should pass with all questions about the quality of the job left to the customer and the contractor. The NEC should not be used as a workmanship code. It is not the stated purpose of the NEC.
At least thats how I see it.![]()
One concern would be the integrity of the connection of the conduit to the panel.
If 110.12 is deemed as unenforcable text why doe's it still exist?
In some facilities, where the owners are the AHJ, 110.12 can be enforceable.
The specs for jobs at these facilities may contain verbiage similar to 110.12 and include 110.12 as a spec.
