NM cables
Depends on whether the staple in question is listed, and what the listing states that staple is capable of holding.
Typically, listed staples are limited to two cables.
I get around this by driving the staple sideways with no cable under it and using a zip tie.
I use these:
You are a very patient man. ;)
i'd be inclined to use a staple gun to set the tie to the stud.
do you trim the tie?
personally, i can't see any good reason to do so being as it is hidden inside a wall.
just out of curiousity, how many of you will admit to cutting holes in drywall and letting the scrap fall inside the stud cavity?
Because when I pull on the cable when I'm stripping out the boxes, the cables move. Drives me nuts. :)
Well, who told ya to wait until trim to strip the cables? :roll: Silly boy!
I strip, make up EGC's and groundeds, and make terminal pigtails and/or hooks at rough. All I need for trim is my electric screwdriver.
Saves time and keeps the freshly-painted walls a lot cleaner, too.
