electricmanscott
- Boston, MA
- Massachusetts Master Electrician, one man show.
If this was a bar someone would have been tossed out on his rear by now.
No, I meant "me". :roll:In the red above, did you mean to say EMF?
I didn't wire this particular setup. Personally I don't use this method but I also have no problem with people who do. When I have installed the light fixture where another electrician wired to this method I have always used the white as the switch leg as it made more sense to me logically. Black is always power, I use any other color as switch leg. Seems simpler that way.. at least we can have one sure thing - black is always hot.
I understand the logic for not using it too however and I will do this the other way from now on but think the code needs to be reworded here. For those making comments along the lines of "any qualified electrician should know this" or similar comments, get a grip and grow up. If you honestly say this isn't the least bit unclear, you are severely undermining everything you say from this point on. There are a ton of very smart people that agree with me, and while they may be wrong as I am, we are not idiots for seeing things this way. So lets not dumn down the entire forum here.
That probably originated from the earliest days of house wiring, with just a lighting outlet in the ceiling, with a pull-chain on a pendant.... back 20 years ago it was a very common way of wiring, as we used to call it spidering, run the home runs to the light box in each room and run one 14/2 or 12/2 down to each device, even the switch for the light ...
You shluld have said "Why don't you order them pre-drilled?" :roll:Back when I move here from Florida in "83", the first electrical job I got up here, I was shocked when they told me to just drill out every stud in each room,I about fell over laughing, I said you got to be kidding.
Power taken to light first, then a cable down to the switch.
I just hate switch loops from a service standpoint. If you have a problem with a switch loop, you've gotta pull the light fix...... errr.... luminaire..... down.
Feeding the switch first makes troubleshooting much easier. If I know the only splices in the ceiling are from the switch leg to the light fixt..... sorry..... luminaire...... then chances are, it's easier to troubleshoot and fix.
Take a look at 200.7(C)(2).
No, as "an ungrounded conductor." They're all CCC's.... and be marked as a Current Carrying Conductor, ...
Aw, shucks! :roll:Larry,
You are right, as usual.
