Is this a Luminaire?
  • Yes.
    Votes: 58 95.1%
  • No.
    Votes: 3 4.9%
  • Can't tell.
    Votes: 0 0.0%
  • Total voters
    61
  • Poll closed .
al hildenbrand
Minnesota
Electrical Contractor, Electrical Consultant, Electrical Engineer
There are, and have been, a number of night lights that are built on device yokes that can be mounted in a standard single gang wall case.
Below is the P&S hallway light catalog # TMHWLCC , an LED light source providing 3 lumens from a 120V supply. It is designed to be covered by a generic decora style device coverplate.
Luminaire - A complete lighting unit consisting of a light source such as a lamp or lamps, together with the parts designed to position the light source and connect it to the power supply.
Using that definition, I vote yes.
Night light?
Night light?
I believe the switch is still a device with an LED in it. The LED is most likely not a replaceable lamp and may constitute as a semiconductor component part of a luminaire. Comments? rbj
I should've created a poll with this. Sorry for the foresight.
Poll: Is this a Luminaire?
1. Yes
2. No
3. Can't tell.
Can a Moderator who sees this please help? Thanks.
There is no switch or receptacle in the P&S device shown. It requires a hot and neutral to work. The nightlight shown is literally only a nightlight.
I will vote yes as well. But that definition should point out whats the aceptable range of lumens that a luminaire got to have, to be considered as a "proper" luminaire.
I would say that it has to be >500 lumens.
That definition came from the NEC. They don't specify a minimum quantity of lumens, so that doesn't come into the discussion. The requirements they call out are a light source, positioning, and power supply connection. All are present in this case.
........ What can you possibly iluminate with 3 lumens? ..........
A dark hallway, or stairway. I've installed dozens of those in houses for just such a purpose. They're far less obtrusive than a plug-in nightlight that gets ripped off by kids running by or the vacuum cleaner.
Imagine three candle flames close to each other in a dark space. . .
a single candle flame have a luminous flux of 4*3.14159(pi) lumens > 3 lumens
I see.
ok.
It was just an opinion. Obviously those things have to have a use, if they doesnt had a use. what would be the reason of making those things?
I have learned something new
Why is it important if the device is a luminaire? It is and I hadn't considered it as such.
This group of light creating assemblies on a yoke have the properties of both a Luminaire and a Device.
Luminaire falls under exclusionary last sentence of Premises Wiring (System).
Device is only in the inclusive first sentences of Premises Wiring (System).
If this assembly is a Luminaire, it is installed at an Outlet.
If it is a Device, can there be an Outlet?
