Is this device grounded?
  • Total voters
    97
I think the proof is in the pudding.
I vote you build 1 small wall, with two openings like you have shown in your diagrams, and forceably fault the dimmers and see if one is "effectively" grounded or not.
Let us know what happens.
he may not be around to let us know.
he should write a note to have someone pass along the results.:grin::grin::grin:
Alright - just for you... I'll hit both with a welder current and see what blows open first... Hows that?
Counting on 2 loose screws for a ground is about the same as just sticking the ground wire threw a hole in the box. Chances are high it will work but neither are NEC accepted. This is hack work, slam your trunk shut and go home cause it works. Unless it is self grounding it need a grd wire to that yoke.
I voted that it was grounded but I went back and looked at the picture. The screws are loose so it is not grounded.
Rather than worrying about interpreting the code, the correct approach would be, would I be satisfied with this installation in my house for my family? Or you could just stick a #14 in the hot side of an outlet while holding the other end in your hand, then touch the device in question with your other hand, and find out if it?s grounded or not.
