ohmhead
- ORLANDO FLA
Well there has been some heated discussions on one post that was about UL listings of products and instructions by manufactures which come with products .
We all use pvc glue everyday and i know that what iam about to tell you is not what you may use its just not cost effective yet but this is the best pvc glue every made .
Heres why when you use this gorilla glue it expands two to fours times its application thickness when applied it fills the voids it bonds and expands .
when water hits gorilla glue it expands and its in the instructions on can you add water drops to its mix to make it work so water would be a benefit .
I know they make underwater glue for conduits but its very expensive but it doesnt expand to seal its just for bonding purposes.
Now if the company that makes this product could reduce the cost we would not have water ever in any pvc conduit underground which is a problem in deep underground work in leaking couplings and such .
I have actually use this and can say you can put lots of water pressure on conduit and it will not leak so your underground work would be free of just common water entering in pvc thur a weak coupling or say around such installs .
Take care
Take care
